foamy oil?
   / foamy oil? #1
rgood
SW Iowa
John Deere 3020
Guys, I went to check the oil on my tractor's dipstick and some of the oil is foamy - The color is normal - At the time I didn't think to smell the oil. The level of oil is OK - I'm not getting any smoke out of the exhaust.
What are your thoughts?
   / foamy oil? #2
I always thoug it was soot. That's bad, it might be bad oil .
   / foamy oil? #3
First thing I think of is water. Check your head gasket. You can do this by blowing air in the engine through a spark plug hole or glow plug hole and watching the radiator for bubbles with the cap off.
Chris
   / foamy oil? #4
I think diamond is right,water will make a milkshake out of your oil.Just make sure you dont run it in that condition.
   / foamy oil? #5
I think it will foam if you have too much oil in the crankcase. But if your engine was cold and had not been running before you checked it, I think water is the culprit as well.
   / foamy oil?
Thanks for the replies - The engine had been running before I checked it as I backed it out of it's spot so I could see better.
If water was the issue, wouldn't the color be milky?
   / foamy oil? #7
Water will make a chocolate milk looking mess. Straight foam is from too much oil in the sump. The crank slaps it around and foams it up. It is really BAD lubricant when full of air.
Let it sit for 15 min, check the level and adjust as needed.
jb
   / foamy oil? #8
In the engine that I have had an experience with water in the oil, the oil was not the normal color but grayish or milky colored, this was in a gas engine which has a little lighter oil color than a diesel.
If the oil level does not rise, it is not likely that water is being added to the crankcase.
   / foamy oil? #9
If it's normal color it's probably overfilled. There is no mistaking when it's water - it looks exactly like a chocolate shake...
2019 NRG BLENDER (A45333)
2019 NRG BLENDER...
(60) HIGHWAY TRAFFIC CONES (A45046)
(60) HIGHWAY...
Ford F-750 XL Super Duty (A44501)
Ford F-750 XL...
2006 JLG 600AJ 4X4 ARTICULATING BOOM LIFT (A45046)
2006 JLG 600AJ 4X4...
Porter Cable 20V Drill (A44391)
Porter Cable 20V...
Simpson 3400 PSI Pressure Washer (A44391)
Simpson 3400 PSI...
