Foaming Diesel Fuel
   / Foaming Diesel Fuel #1
Trails End
Candia, NH
Bobcat CT335
Yesterday, I stopped at the local Shell station to fill two 5 gal.
containers with diesel fuel. I filled the first container with no
problem but while filling the second container, the fuel was
foaming excessively, with resultant foam overflow. I had to
reduce the flow from the nozzle to a very slow rate in order
to finish filling the container without foam overflow.
Does anyone have any idea what may have caused the foaming?
I haven't poured this fuel into the tractor yet, since I'm not
sure if there's a problem with it. Has anyone else experienced
this while filling a container?
   / Foaming Diesel Fuel #2
Winter fuel in warmer temp or pump sucking air???
   / Foaming Diesel Fuel #3
It happens all the time when I'm filling cans at a service station, I just keep moving around three cans to let the air bubbles settle while I'm adding more to a different one. It only takes seconds for them to drop back. It's just the airation of the fluid as it splashes around.
   / Foaming Diesel Fuel #5
   / Foaming Diesel Fuel #6
I always assumed when that happened the tank was getting low. Could be wrong.
   / Foaming Diesel Fuel #7
The fuel in my area also foams a lot, it doesn't matter what gas station I get it from. I always assumed its normal. It also bio diesel in my area so I don't know if that makes it worse or not.
   / Foaming Diesel Fuel #8
We I was active duty, we always had to wait for the foam to settle before we could finish filling our jerry cans. Foamed a lot.
   / Foaming Diesel Fuel #9
Normal. Diesel is more viscous than gasoline; it traps air in fuel as it swirls into containers; foam forms.
Ralph
2015 JOHN DEERE 250G LC EXCAVATOR (A52705)
2015 JOHN DEERE...
2011 CHEVROLET EXPRESS SERVICE VAN (A51406)
2011 CHEVROLET...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
Test Button (A47477)
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
