Tires Foam or no Foam
   / Foam or no Foam #1
chesaw
Bronze Member
Eastern Washington
kubota 4740hstc
Hello, just bought a new 4740 hstc, will be deliverd
next week. I will be filling rears with rim guard, What
do you folks think about Foam in the front tires? I have
thorns and sharp brush on the forest floor on my land.
The dealer says to go with the foam but I have heard
that it is hard on your steering and bearings. Any help
would be welcome on this issue, I have to make up my mind soon.
Wayne
   / Foam or no Foam #2
Foam them all you will never have a flat. My b26 has all four and the M5400 has the foam in the fronts and had a L3300 with foam fronts no problems with probbly 2000+hrs between them. Wish we would have done foam on the rears of the m5400 every time it gets a flat.
   / Foam or no Foam #3
The fronts on my TC29D are foam filled and they work great. The weight of the foam is not carried by the wheel bearings so there should no extra stress on the axle.
   / Foam or no Foam #4
   / Foam or no Foam #5
Gempler's sells a heavy duty rubber tube guard for thorn protection.
   / Foam or no Foam #6
Foam is a little harder on the steering joints. The real issue with the foam is that there is no shock absorbsion in the tires anymore. This causes a rough ride, and can, in some cases, cause pre-mature fatigue on parts (due to the costant "beating" they take). having said that, there are plenty of users who have foam filled tires and have not had an issue. If you are the only user, and use it for relitively "light" duty, there should not be an issue.
   / Foam or no Foam #7
I opted for rubber tire liners inside the tire to protect the inner tube. You get protection plus keep a smooth ride. Good results for me. You can always foam if all else fails.
   / Foam or no Foam
Thanks for all your responce's, This is an amazing site and I really
look forward to posting more when my kubota show's up next week, I am
sure I will have more question's then. I will have my front tire's filled
with foam, I will not be driving on roads and it will be used mostly with
the FEL and a grapple. Again Thank you all.
Wayne:thumbsup:
2022 CATERPILLAR D4 LGP CRAWLER DOZER (A51242)
2022 CATERPILLAR...
E-Z Flow Auger Wagon (A50514)
E-Z Flow Auger...
48in Forks Loader Attachment (A49346)
48in Forks Loader...
10855 Pumping Unit- ENGINE ONLY (A52128)
10855 Pumping...
KUBOTA SVL97-2 SKID STEER (A51242)
KUBOTA SVL97-2...
