Tires foam filled tires
   / foam filled tires #1
the6shooter
oklahoma
MF 1643
This may seem like a stupid question to some, but not to someone that doesn't know. What is the perpose of foam filling tires ?
I have used calceum cloride in the old tires, and antifreeze for weight, just trying to educate myself on the foam filling tires
thanks
   / foam filled tires #2
No flat tires. Like the ones you get for the wheelbarrow. Ride like regular tires, but no blowouts. Great for corn stubble, etc tha does alot of tire damage. Mike
   / foam filled tires #4
Foam filled tires add ballast, are almost indestructible, but are expen$ive!
   / foam filled tires #5
As the others have said, foam filled tires are heavy and flat proof. However the drawbacks are that the process is expensive and I have also read that the ride is not as smooth. I have also read that over the long haul, the stiff tire may lead to more bearing wear on the hubs, etc.
   / foam filled tires #6
Price alone is a shocker, I don't think it's worth it for average residential use, but some guys might find it worth while. The money spent gets a lot of attachments, or even an upgrade in machine depending how much you want to spend.
   / foam filled tires #7
Most people I know with foam filled tires are doing heavy ag work. Great for preventing flats. The ride is a little stiffer. In rocky areas or with a lot of heavy stobs (small trees etc.), can sometimes cause tire to tear up a little prematurely.
   / foam filled tires #8
Honest, I can't tell the difference in the "ride" with my foam filled tires. On the other hand, tractors don't have much in the way of a soft suspension. :)
   / foam filled tires #9
Where can I get my mower tires foam filled?
Branson area
   / foam filled tires #10
My first tractor had them when I got it. I loved the peace of mind. I want to know more than that they are expensive. How expensive?
Yes, I do believe they are harder on front wheel bearings. I've popped the cages off a couple of them.
2019 TAKEUCHI TB290 EXCAVATOR (A51242)
2019 TAKEUCHI...
2019 TAKEUCHI TL8 SKID STEER (A51242)
2019 TAKEUCHI TL8...
Bush Hog 10' Pull Rotary Mower (A50774)
Bush Hog 10' Pull...
TAYLOR WAY (11) SHANK CHISEL PLOW (A51243)
TAYLOR WAY (11)...
Livestock Stall Fan Cage (A50515)
Livestock Stall...
