Tires Foam filled tires
   / Foam filled tires #1
coupman35
Northen Ontario
Now a L4060 had B2650
Am sure this came up before .Am thinking of getting my tire filled whit foam there is a tire shop that does it in town.Am wondering if it a good thing . What your take n this did any one ever got it done and how is it . any info thanks
   / Foam filled tires #2
It’s quite expensive to have done and they ride terrible. A plus or maybe a minus is it’s very heavy.
   / Foam filled tires
Am just tinking of doing the front tire on my B2650 .One tire keep going down it a pain in the but.
   / Foam filled tires #4
You could try the recommended amount of "Slime" in your tires if something is puncturing them. It's possible your valve stem is leaky, too.
   / Foam filled tires #5
I’ve got the front tires on my mower filled. They were constantly going flat and it fixed that problem. They’ve got a half dozen cuts apiece so it was definitely worth it. I paid $40 apiece for the ZT tires and was quoted $300 apiece for my M59 front tires so just putting a tire or tube in is your most economical solution.
   / Foam filled tires #6
All 4 of our tires are foam filled on our TC40D (they were when we purchased the tractor)...
The good...
- no worries on what we drive over in the woods (or anywhere else)
- the weight (it works for us)
The not so good....
- ride quality (especially on hard surfaces) we are almost never on hard surfaces like asphalt, roads , or concrete so it is ok.... just ok....
- Ice... not good... I chain all 4
- Tires have zero give so traction can some times be an issue.... but with 4 wheel drive not usually...
- the weight.... if you need to remove them.... we have a tire dolly (oh & a Lull) so not a really issue.... but something to consider
   / Foam filled tires #7
Foam would be a no return solution. Does your tires have tubes?
   / Foam filled tires #8
I looked into this not too long ago, but decided against it. I was told it essentially makes a solid tire that has to be cut off the rim if the tire ever needs to be replaced.
   / Foam filled tires #9
They last a lot time on dirt going vehicles but that’s true.
   / Foam filled tires #10
I have foam filled on my b26tlb and m5400 and would not own a utility tractor without foam filled. The weigh and fact that I never have a flat is worth every penny it costs. Ride is a none issue for me.
2008 Ford Crown Victoria Sedan (A48082)
2008 Ford Crown...
Chains and Binders (A48837)
Chains and Binders...
2019 GMC Savana Box Van, VIN # 7GZ37TCG8KN009735 (A48836)
2019 GMC Savana...
2019 John Deere R4038 Spreader (A50490)
2019 John Deere...
2019 JOHN DEERE 350G LC EXCAVATOR (A50458)
2019 JOHN DEERE...
2022 Chevrolet Tahoe FL SUV (A48082)
2022 Chevrolet...
