Flux-core wire-feed welding different thicknesses of metal
   / Flux-core wire-feed welding different thicknesses of metal #1
s219
Super Member
Virginia USA
Kubota L3200, Deere X380, Kubota RTV-X
So I plan to practice this tomorrow, but thought I should get some input from folks here.
I have to weld a short 2" piece of 1/8" wall rectangular tube to some 1/4" plate. End of the tube will get welded to the flat of the plate by reaching through the inside of the tube to where it butts against the plate, and place a couple short welds inside where the pieces meet. Strength isn't real critical for this. The welds will basically be wide tacks.
Not sure whether I should set the voltage and wire rate for 1/8" material and know I will have lesser penetration on the 1/4" material, or set for 1/4" material and direct the wire into the 1/4" material then push the puddle up onto the 1/8" tube. Be curious to know what others would do.
thanks,
219
   / Flux-core wire-feed welding different thicknesses of metal #2
I just had to do this for a member over on Welding Web. I took one of my engine drives, and LN-25 wire feeder with .045" NR-212 wire to his house. I had to weld a 1/4" angle iron to .065" galvanized square tube. Flat, vertical, and over head. What I always do is use a J pattern. Keep the long side of the J on the thicker material, and just bounce the curl of the J onto the thin material.;)
Excellent, thanks Shield Arc!
2014 Dodge Charger Sedan (A51694)
2014 Dodge Charger...
2016 International ProStar T/A Sleeper Cab Truck Tractor (A51692)
2016 International...
1999 Case 850G Crawler Tractor Dozer (A51691)
1999 Case 850G...
Adams 6T Fertilizer Spreader (A53473)
Adams 6T...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
