Flushing the Hyd. system on my 180
   / Flushing the Hyd. system on my 180 #1
DJ54
Elite Member
Carroll, Ohio
IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
Does anyone have any pointers on doing a complete flush on the hydraulic system..?? This one isn't as bad, as others I have seen, but want to get it cleaned up ASAP.
I guess my main concern is getting it out of the 3 pt. lift cylinder. The external lines will be easy. I'm thinking drain, with the 3 pt. arms raised, then step on the lift arms to purge the lift cylinder, and let that drain.
After that add oil, and purge the system through the return line. Then do the remote lines one at a time.
I realize it may take 3 times the amount it holds (8 gal.), but will save lots of headaches down the road...
I have read where some have flushed with diesel fuel, but not sure I want to go there... Has anyone used this method..??
Thanks,
DJ
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
2013 Hyundai Sonata Sedan (A50324)
2013 Hyundai...
1266 (A50490)
1266 (A50490)
