Flushing my cooling system
   / Flushing my cooling system #1
1930
Platinum Member
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
Years ago they would put something in rad and let sit overnight, cleaned rad and engine block, more recently I've heard of guys using cocoa cola.
What can you guys suggest?
Haven't even opened cap, I'm just assuming it would be a good idea to flush the system out with something that would work and not necessarily something that's environmentally friendly
   / Flushing my cooling system #2
What color is the current coolant...does it look dirty ? Is the the first time you have changed the coolant ?
I use Prestone radiator flush cleaner first. Drain the system first then fill it back up adding the flush cleaner. Run engine to normal temp then drain . Hook up a water hose to back flush everything out while the engine is running to when it shows clean water coming out. Drain everything and add new coolant . While your at it inspect the hoses and thermostat if they haven't been changed in awhile !
   / Flushing my cooling system #3
I`ve been flushing ALL my engines exactly this way... it`s never failed me yet in 60+ yrs.
   / Flushing my cooling system #4
In all my years I've never had a vehicle with a "crudded up" radiator. I've used Zerex radiator flush and visually it made no difference. I will normally drain - refill with clean fresh water - run for 20 minutes or so - drain - add antifreeze and water mix. What comes out in the fresh water flush is only very slightly discolored water. I always shine a flashlight "down the hole" and see what the internals of the radiator look like. Stick your finger down there and rub on the internal parts - maybe a slight brownish-green film will come off - never anything more.
I think a lot of the "crudded up" radiator problems are due to - what type of water are you putting in your radiator? If you have highly mineralized water then its best to buy and use a gallon or so of distilled water.
   / Flushing my cooling system #5
Every other year or so I will remove the upper and lower radiator hose and flush water backward through the radiator core. I do not get a lot of stuff out but do get some. By running the water from the lower hose it reverses the normal flow of the coolant that would be from the top down.
I do not use any of the flush additives as I feel if I have not got a heat problem running chemicals that "eat" away at stuff to make it cleaner may not be necessary. I have over 5000 hours on my little L2550DT. Additionally, my radiator is compromised by physical damage that happened 20 years ago when it got a stick shoved through the core. It went in between the tubes and pushed the radiator core back somewhat and left a 3/8" open hole through the core. One tough little tractor. It now has a 5/16 steel plate mounted on the brush guard to avoid this happening again.
   / Flushing my cooling system #6
Decades ago, I routinely flushed cooling systems with commercially available flushing chemicals. After changing too many water pumps shortly after flushing, I stopped doing so. Haven't changed a water pump due to seal leakage in 30 years or more.
Flushing with H2O is OK.
That said, if you change the engine coolant per manufacturer's recommendations and use distilled water rather than tap water, you will never need to flush the coolant.
SDT
   / Flushing my cooling system #7
I drain mine. Fill with rainwater. Drain. Fill with rainwater again and run it a few times. Drain and see what it looks like. If dirty, I repeat until clean...then add the new coolant. Never use a flush chemical.
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A49461)
2016 Ford F-150...
TRUCKING INFO (A50774)
2015 Ford Expedition EL XLT SUV (A50324)
2015 Ford...
1999 CATERPILLAR TH82 TELESCOPIC FORKLIFT (A51242)
1999 CATERPILLAR...
2019 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2019 Ford F-450...
