Flushing hydraulics
   / Flushing hydraulics #1
fltem06
West Central Florida
1971 Ford 2000 dsl;1985 Ford 1710 dsl.
I've recently purchased a CUT with a FEL. Hydraulic fluid is milky. When I change the fluid & filter, how do I get the milky fluid left in the cylinders out:confused:?
   / Flushing hydraulics #2
Block up the FEL lift arms for safety, then neutralize pressure in the system by moving the control lever(s) back and forth. Then disconnect the hoses, remove the cylinder, lay it with the ports down and most of the oil will drain out. You probably won't have enough left in them to worry about.
Alternatively, if you have an overhead power source (even a block & tackle) you could use it to support bucket, then cycle the cylinders once you disconnect the hoses.
However you decide to proceed, opt for safety. Keep the weight of the equipment adequately supported and stay out from under any of it.
   / Flushing hydraulics #3
I would just make sure the cylinders are all retracted, then change the fluid-you will have to probably change it at least twice anyway to flush all the bad stuff out...But first you need to identify the source of the water leak.
Thanks y'all:):)
The PO didn't keep it inside or even covered from what it looked like when purchased. I've serviced all of the engine & fuel. Re-cored the rad, and flushed the cooling system. The hydraulics are next on my list.
C
CHAMPION 1 PERSON GAS EARTH AUGER (A51248)
CHAMPION 1 PERSON...
2018 CATERPILLAR 320 LONG REACH EXCAVATOR (A51246)
2018 CATERPILLAR...
(INOP) FORD 9N TRACTOR (A51247)
(INOP) FORD 9N...
UNUSED CFG QH12R EXCAVATOR (A51247)
UNUSED CFG QH12R...
2018 Case TR270 High Flow 2-Speed Compact Track Loader Skid Steer (A51691)
2018 Case TR270...
UNUSED CFG H15R EXCAVATOR (A51247)
UNUSED CFG H15R...
