Flushing Fuel Lines
   / Flushing Fuel Lines #1
Texasmark
Elite Member
N. Texas
Ford: '88 3910 Series II, '80 3600, '65 3000; '07 6530C Branson with FEL, 2020 LS MT225S. Case-IH 395 and 895 with cab. All Diesels
Neighbor accidentally added water contaminated fuel to a T474. Working from the tank through the filters, the pump and bleeding lines at the injectors should be straight forward.
Question: is the pump self bleeding or is there a bleed screw on the pump that allows you to unplug the plug crank the engine till clear, bubble (water) free fuel flows, reinstall the plug and move on to purge the injector lines?
Thanks,
Mark
2012 PETERBILT 388 SLEEPER TRUCK (A51222)
2012 PETERBILT 388...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
2007 KUBOTA M5040F TRACTOR WITH LOADER (A51243)
2007 KUBOTA M5040F...
1274 (A50490)
1274 (A50490)
2006 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2006 Toyota Tundra...
2024 AGT KFE-20 2,000lb Electric Forklift (A50322)
2024 AGT KFE-20...
