Fluids for 1958 Ford 941
   / Fluids for 1958 Ford 941 #1
lonesomedove
newark,ohio
ford
The tranny, hydraulics and rear-end have 3 drain plugs so 3 different compartments.
I was thinking of using a trans-hydraulic fluid for the tranny and hydraulics, and I'm not sure
about the rear-end. Also the drain plugs look like pipe plugs and have square ends on them.
The one for the hydraulics is on very tight, I'm afraid any harder and I will break it off, any
ideas how to loosen one?
Thanks in advance for the info
I haven't but I was thinking of using some heat.
   / Fluids for 1958 Ford 941 #4
The transmission-hydraulic will be suitable for the first two holes, before using it in the rear end compartment verify that it is suitable for hypoid gears.... if not, use a hypoid rated lube.
   / Fluids for 1958 Ford 941 #5
I think the rear end is separate on those tractors. If so 80w90 should be used in the rear. Try heating or tapping the fill plug with a hammer. The drain plugs are pipe plugs with square ends. Heating them will do no harm. Make sure you can open your fill ports too.
Hayrack (A50515)
Hayrack (A50515)
CATERPILLAR VC60DSA SHOP FORKLIFT (A52472)
CATERPILLAR...
Woods 3 pt Box Blade (A50515)
Woods 3 pt Box...
2025 Future Stump Grinder Mini Skid Steer Attachment (A50322)
2025 Future Stump...
3 pt Blade (A50515)
3 pt Blade (A50515)
2010 Chevrolet Impala Sedan (A51694)
2010 Chevrolet...
