fluids and lifts
   / fluids and lifts #1
michellesc7
Western SC and Eastern SC
John Deere 5410 4wd Cab w/ loader, Mahindra 6500 4wd Q/A FEL, John Deere 4120 4wd w/ FEL & John Deere 1050 4wd
hi y'all
i talked to the service dept for my mahindra. i wanted to add some fluids ro my tractor - thought they were low after inspection. received advice to use hydraulic fluid in the transmision case and the hydraulic system of my 4505DI. told it was what everyone is doing now- confirm?. secondly - i have loader lift, but limited 3pt lift. he said to check the knob down and in front of the seat. everything was working, then one day ... i'll take comments and advice.
thks, michelle
   / fluids and lifts #2
Michelle, I'm thinking that you should look to "trans-hydraulic" fluid. Question: Is your hyd pump run off the trans or is it located near the front of the engine on the right side (facing forward)? BobG in VA
2005 JLG 660SJ SKYPOWER TELESCOPIC MANLIFT (A51242)
2005 JLG 660SJ...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2013 Volvo Semi Truck (NOT RUNNING) (A50774)
2013 Volvo Semi...
UNUSED AGT XZ20R EXCAVATOR (A51243)
UNUSED AGT XZ20R...
BE 3 pt Snow Blower (A50514)
BE 3 pt Snow...
7021 (A50322)
7021 (A50322)
