fluid replacement
   / fluid replacement #1
Milist
Mass./N,H.
B2150
fluid replacement
On my B2150, I noticed that my hydraulic fluid was a bit low.
I don't know what type of fluid was used. Is it satisfactory to use transmission fluid to top off?
Also, my manual specifies 10/30 motor oil, but 15/40 is much more prevalent. Would 15/40 be an o.k. replacement?
Does anyone know what number NAPA oil filter to use as replacement and has actually used it?
   / fluid replacement #2
Re: fluid replacement
I don't think transmission fluid is the same thing. Could be wrong on that, but it is probably worth it to pick up a quart of hydro fluid - you can get it at your dealer, over the internet (check out some of the advertisers on the board), or at your local auto parts supplier.
Using a different weight of oil should be fine. Just make sure it is correct for the temperatures you'll be operating in, and don't mix viscosities (change the oil and refill to what you'll be using).
There is a NAPA filter you can use (also a WIX, I think), but I just use the Kubota filters, mostly because I'm lazy. Check out the Oil, Fuel & Lubricants forum and do a search - I've seen this topic posted a few times. But the Kubota filter isn't a whole lot more expensive (if your dealer charges a lot, check out the web suppliers).
But I think you should pick up hydraulic fluid rather than trying to use automatic transmission fluid. I'm no expert, but they are different colors, which can't be a good thing...
2008 HONDA GOLDWING GL1800 TOURING MOTORCYCLE (A50505)
2008 HONDA...
1998 CATERPILLAR D5M PIPE LAYER (A50854)
1998 CATERPILLAR...
2008 FORD F-750(INOPERABLE) (A50854)
2008 FORD...
2016 Ram 1500 4x4 Crew Cab Pickup Truck (A49461)
2016 Ram 1500 4x4...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2019 HONDA PIONEER 5 1000 UTV (A50459)
2019 HONDA PIONEER...
