Fluid pouring out of power take off unit on 1500
   / Fluid pouring out of power take off unit on 1500 #1
dougfollett
Olympia, Washington.
Yanmar 1500
You guys have gotten me through all of my initial problems that turned out not to be problems after all but this time I think I do have a real problem. I hooked up a spreader today to put some fertilizer on my field. I enguaged the power take off (I believe that's what you call it) but I was haveing problems with the material clumping so I got off the tractor to inspect things. I noticed that there was a significant amount of fluid (oil) working its way out around the drive shaft on the rear of the tractor. This can't be good. What do I need to do to remedy it?
   / Fluid pouring out of power take off unit on 1500 #2
Sounds like you need to replace the seal and collar. You may very well have a bad bearing also since you are losing so much fluid.
Thanks,
Bruce
parts@yanmartractors.com
   / Fluid pouring out of power take off unit on 1500 #3
Bruce is right, give me a call and I will walk you through it. Easy to do! /w3tcompact/icons/grin.gif 509-521-1507
2017 Ford F-550 4x4 Enclosed Utility/Air Compressor Truck, VIN # 1FDUF5HT6HED32921 (A51572)
2017 Ford F-550...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
1995 CATERPILLAR 621E (A52472)
1995 CATERPILLAR...
