Fluid leaking out of steering column
   / Fluid leaking out of steering column #1
JD 1250
Milton, Tn
John Deere 1250
I have a 1250 tractor that is leaking fluid from the steering column. It leaks from where the steering wheel attaches to the column. JD says that the parts are no longer available. I am trying to find a way of fixing this. Is there anyone that has any suggestions or ideas on what to do? Or should I just sell it? Thanks
   / Fluid leaking out of steering column #2
It is true that most of the seals for that steering is not available through JD. My first suggestion would be Weaver's Compact tractor ( Weaver's Compact Tractor Parts & Compact Tractor Salvage )parts in Shippensburg PA. We have had good luck finding obsolete parts from them. Call them at 1-866-950-1050. They have used and new parts for Yanmar built tractors. If that doesn't work out, I would take it apart and go to a good hydraulic supply place and they most likely could match up the seals you need.
2014 DODGE CHARGER (A51406)
2014 DODGE CHARGER...
Unused 2025 Bale Spear Skid Steer Attachment (A51691)
Unused 2025 Bale...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
ALLISON TRANSMISSION (A53843)
ALLISON...
Hilti TE 2000-AVR Electric Jack Hammer (A52377)
Hilti TE 2000-AVR...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
