fluid leaking from gear shift boot d3250 fd
   / fluid leaking from gear shift boot d3250 fd #1
klxfl1
Thank you for answering my questions in advance it is kind of you to take the time to help me.
1.Can you tell me why fluid would be coming out of the gear shifting boot?
2. What type of Hydraulic/ transmission fluid goes in the gear box under the seat?
2.5 Where is the drain plug for the Transmission gear box?
3.what type of oil filter it uses?
4. Gas filter it uses?
5. There is K1 on the Engine block is that what it is?
again,
Thank You.
   / fluid leaking from gear shift boot d3250 fd #2
Has the tractor sat outside in the rain allot?
Is the shifter boot torn?
My guess would be the transmission is way over full because of water and the oil is floating out.
Thanks mundy, It could have to much fluid in it,.
KUBOTA L4600 TRACTOR (A51247)
KUBOTA L4600...
UNUSED GREAT BEAR 1.5CY SELF DUMPING HOPPER (A51248)
UNUSED GREAT BEAR...
GOOSENECK COUPLER (A51248)
GOOSENECK COUPLER...
RCcar RC-G4.0 Electric Golf Cart, NEW! (A52384)
RCcar RC-G4.0...
(5) 5' X 20' X 3/8" STEEL PLATES (A51248)
(5) 5' X 20' X...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A53473)
UNVERFERTH 330 -...
