fluid leak from a JD 6415
   / fluid leak from a JD 6415 #1
William09
John Deere 6415
I have a JD 6415 with a a/c cab, I have some type of fluid leaking on the ground the leak is on the left side of the tractor if you were sitting in the operators seat. I am not near my tractor rite now, but last time I checked the engine oil was full, I think the hydraulic fluid was full as well, I think the only thing that was low was the diesel fuel. Any one had this same type of fluid leak? The Tractor runs fine. Any suggestions as to what and where the leak is coming form?
   / fluid leak from a JD 6415 #2
First determine what kind of fluid is leaking. That will go a long way in determining what's leaking.
My JD 6415 has leak that appears to be from the seal retainer for the drive shaft to the front axle, at the transmission end. I wrapped a paper towel around the drive shaft where it enters the seal and that stays dry so I think it's the O-Ring that seals this part to the transmission. I plan to replace it when I change hydraulic oil. My leak is very minor, very slow drip.
Sorry I forgot to mention that I have a 2WD 6415.
   / fluid leak from a JD 6415 #4
If it is on the left side of the engine, then it could be fuel. There are several rubber fuel lines on the left side that tend to leak when hoses dry-rot. A roll of 5/16" fuel hose will fix that.
   / fluid leak from a JD 6415 #5
Fuel tank also has a bottom drain that may be leaking.
Thanks for the input I will look further into the leak this weekend.
PEMBERTON LR129-1123 RAKE ATTACHMENT (A54607)
PEMBERTON...
2016 Ford F-550 Altec AT37G 37ft Insulated Bucket Truck (A52377)
2016 Ford F-550...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
1996 INTERNATIONAL 4700 4X2 DUMP TRUCK (A51406)
1996 INTERNATIONAL...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1ET4EKG11918 (A54865)
2014 Ford F-150...
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
