Tires Fluid in tires
   / Fluid in tires #1
lekwyo
Wyoming
4200 HST
I'm thinking about adding fluid to rear tires. I have a 4200 with 14.00-17.5 R4 tires. From searching the forums this sounds like a do it yourself job. I only have two questions.
Which is best washer fluid or RV anti-freeze? Also my tires are mounted with the valve stems on the inside. Is there a reason for this or should I rotate the tires to get the valve stems on the outside to make filling them a little easier? Any suggestions much appreciated.
   / Fluid in tires #2
/forums/images/graemlins/tongue.gifI used wwaf in my 4300 a coupla years back. No problems to minus 35C. Its not as heavy as calcium but a lot simpler. Also a lot cheaper than RV af. I also have my valves on the inside as this gives me an extra inch of clearance when I add the chains, plus a bit wider stance on the sidehills. Have to remove the tires to add the antifreeze though. Not a big job if you have some means of getting them back up should they fall over. Good luck Pat
   / Fluid in tires #3
Without an implement on the back of my tractor, I had no trouble putting the water in my tires with the valve stems on the inside.
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
2023 John Deere FC 15R (A50120)
2023 John Deere FC...
Fire Truck (A51692)
Fire Truck (A51692)
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
Wooden Sleigh (A50774)
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
