lhfarm
Veteran Member
Back with my 1949 farm jeep hydraulic system. One way cylinder (gravity down). The original system had no pressure relief valve and was closed - not vented. I have added a pressure relief valve and a breather cap. When I put the cylinder under a little load (~300 lbs) it works fine. I can hear a sucking sound when fully extended. If I bump the weight to ~500 lbs, it lifts fine, but when I lower, it "burps" fluid out the vent tube. I placed a finger of a rubber glove over the filler/vent tube and could see the vacuum on extension and the finger blow up as I lowered the small load.
The reservoir is under the jeep bed and I don't have a way of measuring the amount of fluid in the tank. I've been afraid of overfilling, but thinking there might not be enough and that I'm sucking air and then expelling it. The filler tube comes out of the side at the top of reservoir with a 90 degree elbow. Not sure I can easily remove it. Any suggestions for measuring the amount of fluid or should I slowly add fluid until the sucking sound stops?
Thanks,
Thanks,
