fluid change??
   / fluid change?? #1
drjay9051
Morriston, Fl. 40 miles west of Ocala. More cows
Kioti DK 40 HST
in the past fluid and filters has been a messy job. I live on a farm, sandy, no garage floor. Anybody use ramps, jack stands or floor jacks? It would make job easier. I imagine tractor must be level so do i use ramps up front and a floor jack in the rear? Im just tired of the sand and all.
I find myself digging little pits in the sand to get to front axle drain without contaminating the earth. Got to be a better way.
Nothing like being covered with oil and sand. Great feeling!!
   / fluid change?? #2
How bout putting a tarp down and laying on that?
   / fluid change?? #3
I was going to recommend plywood or even cardboard. There's plenty of clearance under these things to do the job. Your issue must be with sand in your crack/hair/ears etc.
   / fluid change??
Yes, also I find it difficult to drain the front axle without spilling oil. Any ideas on this??
   / fluid change?? #5
I start off with a large piece of old carpet :thumbsup: and drive the tractor over it, that way I can lay on the carpet which is a bit softer and cleaner than the ground. Then some cardboard and newspaper so if I spill some oil it won't get into the ground. I make sure I have enough pails to more than contain all the oil. I have a few white pails I got from a restaurant; they are either 2 or 2 ½ gallon size. They work great and fit under the axle. :)
   / fluid change?? #6
Yes, this is what you do. Use the loader to lift the front end of the tractor off the ground. The front axle will rock up and down. Now slide a regular oil drain pan under the entire wheel, tilt that wheel down so that more axle oil runs towards it and then pull the drain plug. You'll get an oily tire but all of the oil will make it into the drain pan. Repeat for the other side. The benefit of this method is that you can get all of the oil out of the axle and also you can fit the drain pan under it. The risk is that you need to keep your hootus out from under things unless you rig up some sort of jackstand.
   / fluid change??
GREAT IDEA !! I suppose left wheel on a couple of boards will tilt to right and vice versa. Yup, use the FEL!! Now I cannot wait to get dirty this weekend.
Thanks a bunch.
BTW: Last front axle change I removed sight glass as per manual, overtightened and stripped it. $15 for new one. Not sure why you need to remove sight glass since you remove fill plug on top which allows for smooth flow of old oil. I just refill till oil is visible in glass. I see no need to overflow out of sight glass opening.
   / fluid change?? #8
Thanks a bunch.
I'm at 31 hrs on my DK35 HST and appreciate the tips given here. I too am confused by the instructions on page 7-17 for Changing Front Axle Case Oil. After draining the oil they say:
=== instruction quote starting at step 2. ====
2. After draining reinstall the drain plugs.
3. Remove the oil level check plug on the left of the front axle
4. Add new oil to the specified level of the check plug through the oil filler. (Refer to "Lubrication" in the chapter "Service".)
5. Tight the oil filler plug after replenishment.
6. .......
===== end of quote ====
Step 4 seems to suggest to add oil until it comes out the check plug hole and I can't find the Lubrication reference, or the chapter "Service" for that matter.
I could not see oil in the window on my tractor but removed the check plug and the oil was level with the bottom of the hole. So the manufacturer seems to fill it just level with the check plug. So why the sight glass with the little floating ball?
To confuse things a bit more they label the sight class as "(1) Oil Filler Plug" in the diagram.
I plan to do the same as drjay and add oil so I can see a bit in the sight glass.
   / fluid change??
6. .......
If you do remove sight glass (and why would you?) be real careful when retightening. It has an O ring so I would think just a bit snug would be just fine. When I sheared mine the metal looks like thin aluminum not the typical type of metal one would find in a bolt. BE CAREFUL !!!! I think adding till level is just above bottom of glass is a better idea than removing the sight glass plug. Why sight glass if they tell you to remove? In any event enjoy .
   / fluid change?? #10
Thanks for the warning drjay. I did remove the sight plug to check the oil level because I could not see oil in it. I was fortunate to have read another TBN thread warning about not over-tightening it as it strips easily.
I agree, I'll add oil until I can see it in the sight glass.
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
2006 Volkswagen Jetta Sedan (A50324)
2006 Volkswagen...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
2008 FORD F-350 (A52472)
2008 FORD F-350...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
