Ellen B
Hi everyone, I've got a Kubota L2501 with a hydraulic fluid capacity of 6.2 gallons. I just performed the 50 hour service, and changed out my hydraulic fluid as part of that. When refilling it I poured in roughly 5.5 gallons, and then ran the tractor for few minutes before topping it up, because I'm unsure if I need to circulate the fluid to get a correct reading on the sight glass. When I checked the sight glass, the fluid line was in there so I didn't add any more fluid.
Yesterday I removed the backhoe, attached the three point hitch, and did about an hour of work with a box blade. The tractor was operating just fine, but when I got off to take a break I noticed that the fluid was gone from the sight glass. I had purchased 7.5 gallons of fluid for the change out, and I added the remainder of that but there's still nothing in the sight glass. This morning I purchased another jug of fluid, and have already added about a gallon to the tractor, still without getting it to come up to the sight glass.
At this point, I've added about 8.5 gallons of fluid when the manual says I should've needed 6.2. I didn't spill any during the refill or backhoe disconnect, and I'm 100% positive that none leaked out while it was parked. I hadn't operated the three point hitch before yesterday (after the fluid change) in case it matters. Could there be that much fluid stuck in the backhoe (BH77, can't find fluid capacity specs though)? Or is there something else I'm missing? I'm hesitant to continue adding fluid until I figure out what is going on.
Thanks for your advice!
