Fluid capacity for CK20 HST
   / Fluid capacity for CK20 HST #1
hotairballoon
The answer to this is here somewhere, but search gives me a 404 so: How much hydraulic fluid is in a CK20 HST. Manual says between 5 and 6 gallons, but someone who claims to have recently changed it claims 16 gal. Seems impossible to me but I dont want 10 gallons fluid all over the place:( . I dont know what tractor he has for sure.
   / Fluid capacity for CK20 HST #2
It is not 16 gallons. My CK30 was done in about 7 gallons. Buy it by the 5 gallon pail so you have left over.
Thanks, I didn't see how he could be right, maybe he sells the stuff?:D
   / Fluid capacity for CK20 HST #4
My manual says 4.89 gallons.
   / Fluid capacity for CK20 HST #5
I am at my 50 hour service as well for my ck30 HST, what brand/type of hydraulic oil is a good premium oil?
Thanks in advance
Randy
   / Fluid capacity for CK20 HST #6
randot said:
....what brand/type of hydraulic oil is a good premium oil?
Randy
Your owner's manual lists several name brand tractor-hydraulic fluids. I
use Chevron 1000THF. It is important to use THF, not hydraulic fluid
for best HST and wet brake performance. The colored THF is very
nice, too, since it is easy to see on the dipstick and you can tell
what is leaking easier.
   / Fluid capacity for CK20 HST #7
Thanks for the reply, I used the Shell Rotella tractor multi purpose hydraulic oil, could not find the Chevron brand or the exact products in the owners manual. Seems to work just fine, mowed with it 4 hours this last Sunday. I do have a small seep on the larger hydraulic filter and it is as tight as I can safely get it. Have you experienced that problem?
Randy
   / Fluid capacity for CK20 HST #8
Did you clean the filter boss and lube the filter oring with oil or grease before putting it on? If you just wiped the boss dry and put the filter on ,it has tendency totwist the oring and will leak. Tightening it more usually doesn't help.
Try loosening the filter just til a little oil runs out and then retighten.
   / Fluid capacity for CK20 HST #9
I will give it a try on the filter, I did the lubing of the gasket etc, it's the first one of that type I've leak in a long time.
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
CASE TV370B SKID STEER (A51242)
CASE TV370B SKID...
UNUSED AGT ATK-B1000 2 POST HYD CAR LIFT (A51244)
UNUSED AGT...
UNUSED AGT QUICK ATTACH AUGER SET (A51244)
UNUSED AGT QUICK...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
