Fluid capacities???
   / Fluid capacities??? #1
Porkie
Bronze Member
Carthage, Missouri
2000 New Holland TC40D-HST
I can't for the life of me find my owners manual that came with my new, at the time NH TC40D (year 2000) and I need to know a couple of things:
Mine has the HST and the 16LA loader and I need to know total capacities in gallons and quarts, ounces etc, for the complete maintenance that I am now doing, so I can buy and adequate amount before hand.
Does the front end of the 4WD run HYD fluid also or is it hypoid gear oil?
I am putting a new fuel filter and oil filter on immediately because I have some on the shelf but I will have to buy the HUGE filter on the right, underneath the riders platform and the smaller one on the left front of the engine.
How many filters are there?
I tried to research this and wasn't successful at all and would appreciate help!!!
Thanks, Sam
   / Fluid capacities??? #3
The front axle and drop boxes all use hydraulic fluid (Multi-G 134). I suggest you buy 10 gallons of fluid total. You'll use about 8 gallons when you drain the transmission/hyd reservoir and another gallon or so in the front axle. That will leave you with an extra gallon for topping off your system before the next change/fill. I think because of quantity purchasing, you can buy 10 gallons (in 2-1/2 g jugs or 5 gallon pails) as cheaply as buying 7.5 gallons and then 4-6 quarts for the rest.
Here is a link to the page containing all the filters for your tractor at Messicks.
Thanks Jim--I really appreciate it. You always seem to be there for "us!"
Hopefully soon I will be able to see If my Hyd pump overhaul was successful!
Take care all!
Sam
Compact Track Loader Skid Steer (A59228)
Compact Track...
INGERSOLL RAND G25 GENERATOR (A58214)
INGERSOLL RAND G25...
New/Unused Quick Attach Pallet Forks (A57454)
New/Unused Quick...
New/Unused AGT Air Compressor (A57454)
New/Unused AGT Air...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
THREE POINT ATTACHMENT (A58214)
THREE POINT...
