Flow reducers
   / Flow reducers #1
jdonovan
Central Virginia
I have a new-to-me snow plow that I've gotten setup for use on the skidsteer QA on the loader.
The problem I'm finding is that even at idle speed the 3rd function loader valve is moving the plow WAY to fast. I've picked up a pair of flow reducing valves to put on the lines.
I was wondering about putting the flow valves on a pair of QD's so I could use them with other implements vs. putting them on the plow setup only.
Thoughts?
   / Flow reducers #2
there are many pressure and flow control valves as long as yours is designed to be in-line and permit return flow you should be good
   / Flow reducers
Yes, the ones I have are inline, and have no resistance to return flow.
2022 SIDUMP'R 48FT TRI AXLE SIDE DUMP TRAILER (A54607)
2022 SIDUMP'R 48FT...
HYDRAULIC PTOS (A53843)
HYDRAULIC PTOS...
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
2002 Wacker RD11A Tandem Smooth Drum Roller (A54811)
2002 Wacker RD11A...
