Flow Control Valve Problems
   / Flow Control Valve Problems #1
frankmako
Bronze Member
North Georgia
Ford 4610, Ford 3910 and YM1601D
The flow control valve knob for the hydraulic controls on my Ford 3910 II will not turn. Is there a lock screw or something that I need to turn first?? It is set to the maximum correction rate. Everything works as it should, 3 pt hitch and FEL goes up and down. Should I not worry about this?? Or do I need to do some work on the hydraulics.
   / Flow Control Valve Problems #2
If you're talking about the plastic quarter-round knob, it's the adjustment for depth correction rate or speed. I talked to the local dealer and he says it's a common problem. He says to keep spraying the shaft with Liquid Wrench or similar to free it up. Mine is stuck in fast mode which is ok. Unless you plow in many different soils, it doesn't get moved often so I wouldn't worry about it.
I've been spraying mine about every other day for the last two weeks but it's still stuck. :rolleyes:
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
UNUSED CHERY INDUSTRIAL SINGLE GARAGE METAL SHED (A51248)
UNUSED CHERY...
2017 John Deere HPX615E 4x4 Utility Cart (A51691)
2017 John Deere...
2017 KOMATSU PC228USLC-10 EXCAVATOR (A51246)
2017 KOMATSU...
SHOULE RM8080 LOT IDENTIFIER 67 (A53084)
SHOULE RM8080 LOT...
JOHN DEERE WHEEL LOADER 71" FORKS (A51246)
JOHN DEERE WHEEL...
