Thanks for that information. So as the spool moves into the work position, the pressure rise is variable? The varying of the pressure/spool valve is what increases or decreases the speed of the FEL cylinders opening and closing? For the sake of argument, if a backhoe and FEL are to be utilized off the same Fixed displacement gear pump (not running at the same time), yet one operates at 10 gpm and the other at 15 gpm, how does one reconcile the different needs of each implement? Essentially they will both function, but will respond to the spool valves in different ways?
My understanding is that as the (open center) spool valves moves into the work position, it doesn't directly raise pressure, it diverts flow to a cylinder or some other "end user" (pump, etc..) that presents a resistance/blockage. It's that resistance that builds pressure (from a pump turning out a constant flow) until it's great enough to force the blockage to move (i.e. the cylinder strokes). That is, if the spool valve diverted oil to a cut hydraulic hose line dumping on the ground, there'd be relatively little pressure (unless you tried to restrict the flow).
I would say that the pressure rise is a function of how much mechanical resistance is on that cylinder. That is, if the cylinder has no mechanical load on it and (say, making up numbers) 100 psi can make it stroke, the pressure won't build to more than 100 psi. (Until it hits the end of stroke, then pressure will rise dramatically to the point a relief valve (recycle control?) should open elsewhere; otherwise pump engine stalls or something blows up.)
The oil will flow in the path that has the least resistance when given a choice (i.e. it will stroke the cylinder that needs the least pressure to do so.)
I believe the pump's GPM numbers are really going effect how fast the pump can fill the volume of those cylinders, or multiple cylinders at once, and ultimately how fast you can operate the attachments. I don't think it should effect the pressure of the system or "strength" capacity of the cylinders.
You want a 15gpm pump to operate the larger "15 gpm attachment" at "recommended" speeds.
If I'm in error, I hope somebody else chimes in
