Florida Cattle Info Needed
   / Florida Cattle Info Needed #1
RMEADOWS
Bronze Member
Lakeland, Fl
MF 1428
I've got 20 acres and want to raise some cattle and do not want to loose money i the process. Anyone have any suggestions or know where I can get info on raising/selling cattle?
   / Florida Cattle Info Needed #3
There's also a book by Storey called Cattle Raising. You can get it at amazon.com.
   / Florida Cattle Info Needed #4
You may want to consider miniature cattle for a small acreage. Dexter is one that comes to mind. I'm looking into them myself. I understand they require less pasture to sustain themselves compared to standard breeds (Angus, Hereford, etc.) You can keep two well fed per acre of minimal pasture, they forage and thrive on weeds and grasses other cattle avoid. Dexters are originally from Ireland where farmers put them out on pasture that was unpalatable to other bovine. You can raise them at half the cost in feed and get comparable yields of meat. They say a Dexter steer with a finishing weight of 800-900 LBS. will yield 60% or 480-540 LBS. of beef. I've raised both Angus and Herefords which finished at 1200+ LBS. that yielded at best 590 LBS of beef.
Here's a link that may help: <A target="_blank" HREF=http://www.minicattle.com>http://www.minicattle.com</A>
   / Florida Cattle Info Needed #5
You may want to try the "Florida Cattlemen's Association"
<A target="_blank" HREF=http://www.floridacattlemen.org/Appexln.htm>http://www.floridacattlemen.org/Appexln.htm</A>
   / Florida Cattle Info Needed #6
Ditto on the book Cowboy Doc mentioned. It's by Heather Smith Thomas and it is an excellent reference. My copy is dirty and muddied from taking it to the barn and out in the field with me. Very common sense approach and written in layman's terms. Even old cow hands can learn a thing or two from this book.
Good luck.
UNUSED Bubble Aluminum Foil Reflective Insulation (A53117)
UNUSED Bubble...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A54811)
Generac Yanmar...
2005 Chevrolet Trailblazer EXT 4X4 SUV (A51694)
2005 Chevrolet...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A53422)
2015 Ram 3500 4x4...
