rozett
Platinum Member
- Joined
- Mar 23, 2002
- Messages
- 730
- Location
- Maine
- Tractor
- Cub Cadet 7360SS & Craftsman GT3000 23 HP w/50
OK, I'm sure someone on this board can help me. I've spent an hour on the web looking for joist loading information and all I can find is span tables.
Background: We have a barn that is well over 150 years old. The post and beam construction is raised above ground level. The north wall sits just about ground level, with the south wall about 5 feet above ground level (35 foot span). The barn was rehabilitated by the previous owner. Besides reskinning it, they removed all of the original floor boards and replaced them with 2x10's @ 16" OC topped with 3/4 ply. This results in joists of 11' 2" span hung from 2x12 rim joists with standard stamped hangers.
I've built two 11x13 stalls on one side of the barn, where we house our two horses (1000 & 1200 lbs). The floor always had noticeable deflection with the horses moving around their stalls. Well, after about four years, the floor joists have started splitting or broken completely. Obviously, the 2x10's aren't enough to support the load. I've looked for tables that provide loading info for various joist sizes, but all I can find is span tables for the standard residential loads of 30, 40, and 50 psf.
My thoughts are to replace the single 2x10's with a pair of sistered 2x8's with 2x4 blocking nailed below the joist hangers and to use 3/4 underlayment instead of regular 3/4 ply. I'm trying to find the loading specs for 2x8's vs 2x10's. I want to make sure that's going to be enough. I could sister 2x10's but wouldn't be able to block them.
So, there's got to be a contractor in this group.
