Floor jack and stands, what's a good one?
   / Floor jack and stands, what's a good one? #1
gsganzer
Elite Member
Denton, TX
L3800 w/FEL and BH77, BX 2200 w/FEL and MMM
I need a decent floor jack and stands, mainly for changing/rotating tires and such, largest vehicle is diesel F250. What's a decent one?
   / Floor jack and stands, what's a good one? #2
I bought a set of stands at Sears that were rated for 5K pounds. They are a pretty simple piece of equipment and I think any of them would be fine up to their ratings. I also bought a pump jack at my local NAPA auto parts store that is pretty decent..just heavy. Also picked up a aluminum pump jack at harbor freight ..not sure of its capacity but it picks up a F150 with no problem..and it's light.
   / Floor jack and stands, what's a good one? #3
I bought a "racing Jack" at Harbor Freight. Really like it: twist handle like the commercial ones. Very low.
Ralph
   / Floor jack and stands, what's a good one? #4
I have some old Walker 5000 lb stands. I supported 1 axle of my backhoe with one a while back. Been using them for everything since 1983 with no failure.
   / Floor jack and stands, what's a good one? #5
I bought heavy duty (6 ton) jack stands years ago from Northern Hydraulics, they have held up just fine...
SR
   / Floor jack and stands, what's a good one? #6
I use this one from HF- Daytona™ Low Profile Car Jack
from the DIL G37x to my F-2fiddy 20" lift is awesome.
Jack stands are 6 ton rated from NAPA.....because of the Kioti and F-2fiddy.
the autozone 3ton stands made me feel uneasy so I gifted them to BIL.....
The 6 ton stands are beefy, heavy and have no issues using them to hold up cutter for blade sharpening, under the truck or jacking up the kioti....
   / Floor jack and stands, what's a good one? #7
Note that jack stands and ramps (that are usually used in pairs) are (usually) rated for the pair. Scrutinize the specs!
Cautionary Tale: I have used the same pair of steel ramps for oil changes on my diesel 2500 many times. Last month the rear wheels spun in loose gravel. I took about a 3' running start, mounted the ramps, and braked when I felt the wheels crest the "knuckle". Braking transfers weight to the front axle; the force was great enough to collapse both ramps. In investigating replacement ramps I found many instances where the advertising copy was not explicit and could easily mislead someone to believe the appliance was twice as strong.
   / Floor jack and stands, what's a good one? #8
I have 2 Arcan floor jacks I got from Costco years ago great Jack no problems.
   / Floor jack and stands, what's a good one? #9
I wouldn't lay under anything that said H.F. or costco with a 9,000 lb. truck over me . I have a set of 12 ton ratchetting, 22 ton pin , 10 ton pin and a set of high rise 12 ton stands . All were bought after my diesel f350 broke the ears of 2 3and 5 ton ratchetting style stands .:eek: Amazon usually has good deals on sunex and otc. The 12 ton pin was like 80$ free dilevery . I feel very secure laying under the truck . Cheap life insurance.:drink:
   / Floor jack and stands, what's a good one? #10
I have an old set of Sears Jack stands that are rated at 6 tons per pair. My old 3 ton floor jack is marginal in lifting the front end of my F250 gas truck - it will do it, but barely. I just rotated my tires a few days ago, and I did the front one side at a time.
I second the opinion of avoiding the HF cheap stands... They had a recall not long ago on some jack stands. I will say their terms for replacing or refunding were very liberal.
Harder to find, but if you're supporting an F250 you may want to look for some taller jacks rather than the typical automotive stands. I use 4" of oak under mine for the extra height (and to keep them from gouging the pavement).
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
1996 Ingersoll-Rand VR642C (A47477)
1996...
2015 Peterbilt 337 Pac-Mac KBF-20H Forestry Grapple Truck (A53422)
2015 Peterbilt 337...
2008 FORD F350 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F350 XL...
Informational Lot - Shipping (A55218)
Informational Lot...
