If I didn't want to have implements on rolling dollies, I would have just put down plastic and then dropped gravel down (perhaps #8 or crusher run -- #8 is nice because it self compacts, though it would probably stick to muddy tires). Concrete was expensive, and a hassle to find a contractor (should have just done it myself). And as Eddie Walker points out, kind of kills the cost benefit of a pole barn.
If you just need an office lunch area in a section of the barn, I'd say put down plastic, then gravel, and then build up a floor deck with lumber where you need it. Pressure treated frame (can be 2x4 if resting directly on gravel or well supported with blocks, and just for foot traffic and light loads) with some 3/4" T&G plywood will be nice and firm, and not too expensive.
