I'm getting closer to pouring the slab for my barn, and thinking about the stuff I want to have under the slab. I'd like to have a floor drain to clean out the inside. While our land is totally flat, I had the ground under the barn built up 24" and compacted when our pond was dug, so there is some slope for the drain.
My first thought was to simply dig a hole a short distance from the barn and construct a drywell for the water to drain. Then, I started thinking about the projects I'd be doing -- most involve mechanical stuff and painting, with the high probability of spills of oil, grease, paint overspray, thinners, etc. This isn't stuff I want to wash down the drain and have go directly into the ground.
What kind of clever, cheap solutions do you know? I'm not looking for a multi-thousand dollar closed water recycling system, more of a Mother Earth News idea. I did a google search for floor drain problems, but most of the solutions involve eliminating the drain. This doesn't help; when I degrease an engine, the stuff has to go somewhere, either into a drain or out the door.
