Floating ring for NH
   / Floating ring for NH #1
SkidTC33D
New Holland TC33D
I have water in my diesel. To catch this problem faster next time I want to put a floating ring in my sediment bowl/ fuel filter bowl. I have seen them on Mahindra and JD but not New Holland. Any tips on where to get one? Has anyone been able find one that fits on a NH? I have a TC33D.
   / Floating ring for NH #2
Looks like one from a jd 770 tractor will fit. That's the one i got for the kubota it was around 3.00
   / Floating ring for NH #4
There's nothing special about the floating rings in sediment bowls, as long as it physically fits. That said, it's not difficult to see a water line without the ring.
I replace the primary filters on my diesels with larger Racor water separating filters. They are the best and easiest to service filters I have ever used.
   / Floating ring for NH #6
My question - why not fix the cause of the problem. Where is all the water coming from - fix that. Been out here on the "80" for over forty years. Never, even once, had any problems with moisture/water in my fuel.
I would guess that SkidTC33D has some type of storage problem that needs correction.
   / Floating ring for NH #7
Welcome to TBN.
Another solution to eliminating water from your diesel is to use a Mr Funnel that has a membrane filter that does not allow water through it:
Home
First however is to get all the water out of your system, then when you use the Mr Funnel the system should remain water free.
Is your tractor stored outside in the rain, if so check that your fuel cap is not cracked.
Perfect. I will pick one up and see it it will fit. I have been keeping the tank full to reduce condensation and adding fuel stabilizer but clearly not doing something right. With the ring at least I'll be able to more clearly see when I have water in the tank.
   / Floating ring for NH #9
I had water in fuel once, self inflicted. I drained the tank, removed fuel filter and water collected, and put same fuel back in using Mr. Funnel. What residual water left in tank passed into fuel filter housing, so I drained again. adding new fuel filter. Water is so easy to see when using off road fuel. (purged fuel lines to injectors just in case)
   / Floating ring for NH #10
I agree with the other's. If you wait to catch the water at the filter, you will have more problems down the road like algae and injectors. It sounds like your fuel supply is contaminated at the source and that should be taken care of pronto. I would get a fuel sucker tube to the bottom of the tractor's fuel tank and suck up what is at the bottom.
IH Cub Lo-Boy 154 (A50514)
IH Cub Lo-Boy 154...
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
2012 Audi Q7 AWD SUV (A50324)
2012 Audi Q7 AWD...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
KJ 45'x25' Metal Garage (A50121)
KJ 45'x25' Metal...
