Floating dock...
   / Floating dock... #1
dooleysm
Platinum Member
Southern Indiana
I'm planning on building a floating dock on my small pond here in the next month or so. I'm going to anchor the dock to the shore with 2 I-Beams burried in concrete. To the I-Beams will be attached a walkway, hinged at both ends, attached to the floating dock portion.
I've located a steel structure that was previously used by my in-laws to hold pallets of shingles at their construction supply yard. It is a steel frame with angle iron cross members every 16ish inches (maybe more, maybe less, I haven't measured yet). It's 4 feet wide. I know next to nothing about working with steel. I do know that steel costs a fortune now and I cna have this structure for free. I've got some buddies that can do a servicable job of welding and cutting steel that are going to help me.
My biggest question now is how to prepare the steel structure. It was previously used under an overhang, so it didn't get much moisture. For the past 18 months it's been sitting out exposed to the elements. It's accumulated plenty of rust in that time. I'm wondering if it's even worth worrying about the rust though. My thought is that if it takes 30 years for it to rust to the point of failure, then it will have more than served my purposes and my children's purposes (I'm 28 with a 4 month old son and more planned).
If it turns out that I should do something to protect the steel, what should I do? We've been toying with wire brushing it (with the help of an air compressor and grinder tool) and then painting it with Rust-oleum or using a 'rust converting primer'. This issues goes beyond my knowledge or that of my friends that are helping me.
Any thoughts?
shawn
   / Floating dock...
Any thoughts?
shawn
   / Floating dock... #3
Wire brush it real good, use Rust-oleum primer and paint. When I built the ramp for my dock that's what I did, and it still looks pretty good after 15 years.
   / Floating dock... #4
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2024 JOHN DEERE 6110M LOT NUMBER 56 (A53084)
2024 JOHN DEERE...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
48" WIDE WOODEN STAIRCASE W/ METAL RAILING (A54757)
48" WIDE WOODEN...
2012 Cadilac SRX SUV (A53424)
2012 Cadilac SRX...
