So I have an older cub cadet model 1812 with a kohler magnum 18 engine. I jus recently had the engine out to replace an ignition coil (caution when replacing key switch do not put 12v to the yellow wire! It's a 115 dollar mistake!). I get it all back together and try to start it and it floods out. So I yank the carb off to find the float bowl is stuck. I free it, blast the carb with some carb cleaner put it back on and it's fine. Tractor sits overnight and I mow the next morning. No problems. I take a 2 hour break go back out and it's flooded again. Any ideas what could be goin on here?
