Float function: L3130 remote valves?
   / Float function: L3130 remote valves? #1
texbaylea
Veteran Member
Brazos County Texas 77808
Kubota L3130HST w/LA723 loader
I have 3 remote hydraulic valves installed on my L3130. Valves 2 and 3 return to center normally. Valve 1 has to be pulled back to center from the push stroke and will stay back on the pull stroke.
Could this valve have the float function? I did not order it that way but the dealer knew that I planned to use #1 for a hydraulic top link.
I had thought that the PTO control cable was interferring since it lays against the lever but it is too flexible and loose to do that.
Anyone have a remote that they know has the float function?
Vernon
   / Float function: L3130 remote valves? #2
Vernon
It may be for float or it could be for feeding oil to a 3PH attachment like Logger Splitters that use the tractor hydraulics to run. When left in the push stroke position does the hydraulics on tractor still sound like it is under load. If it does then it is not for float. It is for running an attachment.
   / Float function: L3130 remote valves? #3
If you have the factory valves then it is the float. They do not offer a non-float detent full stroke valve.
Float detent valve option number is L8304.
Non-float option number is L8303.
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
3014 (A50657)
3014 (A50657)
CATERPILLAR 304E CR EXCAVATOR (A51242)
CATERPILLAR 304E...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A52128)
3-Point Hitch Root...
1985 Toyota Pick Up Truck (A50515)
1985 Toyota Pick...
2013 UTILITY VS2DX 53FT DRY VAN TRAILER (A51222)
2013 UTILITY VS2DX...
