Flipping over
   / Flipping over #1
amazincaucasian
Bronze Member
mo
2013 Kubota kx-121, 1988 Kubota L2202DT 1998, Bobcat 331 bobcat, F800 dump truck
They all will come over forward if you decelerate suddenly with the bucket up, especially when it's loaded. The rubber tracked loaders seem more stable to me. But I use a 763 all the time and it will tip with a full bucket of heavy material (sand, red clay gravel) when I come up to load my dump truck. If the machine has a material bucket, watch out!! The tip factor goes way up.........Just have to get a feel for what it takes to get it tippy.
   / Flipping over #2
any wheeeled bocbat can tip over frontwards, if the load is enough, and the conditions are right. you can buy weights that help with the tippy front end issues. the tracked machines are much more stable. the wheeled machines are great, especially when they can pivot and turn on the front wheels only. they can only tip as far as the bucket will let them.
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52748)
2024 BCL...
2009 Ford F-650 24 ft Box Truck - 6.7L Cummins L6 Engine - Automatic Transmission - Low Mileage (A52748)
2009 Ford F-650 24...
2012 Ford F-450 Altec AT200A 30FT Bucket Truck (A50323)
2012 Ford F-450...
Kohler 30 Generator (LOCAL TOWNSHIP) (A50774)
Kohler 30...
Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
Turfco...
