Richard
Elite Member
- Joined
- Apr 6, 2000
- Messages
- 4,985
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
\"Flex wing\" rotary cutter question
Looking at Bush Hog's website, they mention that the "wing flex" on this unit will move from </font><font color="blue" class="small">( 90° up to 22° down )</font>. I understand that the 90° up is in the transport question.
What I'm curious of is, as you are working the unit, will the whole ensamble "flex" a bit to follow the contour of the ground, such that during usage, if the wings need to have "zero" degrees elevation/decline then the next 20 feet, they need to dip to 15 degrees down, will it happen automatically?
Given I noticed the hydraulic ram used to lift the wings up, my guess (fear) is they will go to 22 degrees "down", only if the ram pushes them down, and the same ram will help prevent them from moving up, until it's done hydraulically.
What I'm leading to is scalping. Seems to me, if they will "flex" on a dynamic basis, they will follow the contour of the ground much better. As I live on some rolling hills area... I've been wondering about this and their website (thus far that I've seen) doesn't make this clear.
I talked to a salesman once at end of last summer and he kinda only glossed over my question, saying..."uh.. no problem". Frankly, his answer (glossing) is one reason I didn't pursue the whole situation further.
