/ Flex 4 hsu #1
workingwithwillie
Mahindra 4500 four wheel drive
Started pushing fluid out under the steering wheel...got frustrated by what I researched on replacements and seal kits available ..took it out tore it down found the inner shaft seal obliterated or close...it was a rigid seal just like the outer shaft seal...was able to make a replacement with another o ring and some jb weld as the wall for it...put it back together and have been running it for about 10 hours so far..NO leaks and function is good...it is doable..don't let ppl tell u that a crossover kit to flex 5 is the only way.
10ft Rotary Cutter (A57454)
10ft Rotary Cutter...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
Auger Drill Bit (A56860)
Auger Drill Bit...
2015 Dodge Charger Police Car, VIN # 2C3CDXAT0FH817478 (A57453)
2015 Dodge Charger...
2021 Kubota SVL75-2 Track Loader (A56438)
2021 Kubota...
