Flat Tow Backhoe -- no trailer
/ Flat Tow Backhoe -- no trailer #21
My concern driving it isn't just the time, but it is not very safe to drive 15mph when everyone else is going 55mpg behind you,.
It isn't as unsafe as you make it sound.
I have spent the majority of the last month in tractors on the road doing 20mph.
/ Flat Tow Backhoe -- no trailer #22
I recently purchased an old Case 310B backhoe, it is basically a tractor with a loader and backhoe, it weighs in about 9000 lbs. It has the big 24" tractor tires. I'm wondering if I can flat-tow it, i.e. let it roll on its wheels when I tow it. I'd go slow. It is a bit far to drive it, about 75 miles, at 10mph that would take 7.5 hours. I'm thinking 30-40mph, so only 2-3 hours.. :)
Can the tractor tires/wheels/transmission handle going that fast?
Alternatively, can it be towed by a wrecker tow-truck, i.e. with the big rear wheels on the ground, same kind of issue if it can handle the speed.
Thanks, Jack
About 90% of the repiles on here advise against it. That would be enough for me. But go ahead, since it sounds like that is really what you have already decided to do. :D
Please update us after you do and we'll have good evidence to relate the next time this comes up. :)
/ Flat Tow Backhoe -- no trailer #23
Fact is the gears and being geared so low, they just werent designed to by cranking so fast like that..
/ Flat Tow Backhoe -- no trailer #24
either drive it or haul it because if it a shuttle shift tractor u will burn the pump the torque converter and the clutch packs in the tractor if you drag it very far
A rental yard rents a 10k equipment trailer for $75/day,
and I can rent a 3/4 ton truck for $100/day, so at that price it isn't a problem to just trailer it, and I have acquired a F350.
Just my opinion, but it is a manual shift tractor, when its in neutral the gears don't matter, and I think it could flat-tow with the front wheels up no problem at least going slow. 30mph or so. So lack of rear brakes would be the only issue, which if limited to 30mph wouldn't be that big a problem. I did figure a route through the country which we scouted out recently and only required about 10 miles on the 55mph no-shoulder 2-lane road, so driving it wouldn't be so bad as originally thought in terms of safety.
/ Flat Tow Backhoe -- no trailer #26
I recently purchased an old Case 310B backhoe, it weighs in about 9000 lbs. It has the big 24" tractor tires. I'm wondering if I can flat-tow it, i.e. let it roll on its wheels when I tow it. I'd go slow. It is a bit far to drive it, about 75 miles, at 10mph that would take 7.5 hours. I'm thinking 30-40mph, so only 2-3 hours.. :)
Thanks, Jack
It is hard to even imagine this for such a long trip :confused2:
There are so many things wrong with this idea, how would you even begin to get it to track behind the tow vehicle?? I would think it would be all over the road at 10 mph, never mind 40 mph.
Nothing wrong with thinking up the idea, but I don't think you should try it.
Find an equipment trailer, as hard as that may be, you will be saving yourself some serious time, effort, money, liability, future driving privileges etc etc in the long run.
JB.
/ Flat Tow Backhoe -- no trailer #27
How would you do this? with a HD wrecker? can't be cheaper than the trailer rental.
JB
/ Flat Tow Backhoe -- no trailer #28
ahh thanks. i checked u tibe and thought that was it.Ive heard of people who set the front bucket in the truck bed and use down pressure to lift it off the ground and then tow it like that. short distances..
I worked in the oil patch in the 60's we moved the backhoe that way all the time,we had a big ball and coupler we attached to bucket .Farthest we ever went was about 30 miles usually only about 15 ,daily.
/ Flat Tow Backhoe -- no trailer #29
I would be most concerned if this is old and may be lacking on maintenance what will be wrong inside all ready ,and the old rubber may last years doing a bit of personal work but you could blow a less than premium tire and that will make the $400 look quite cheap.
/ Flat Tow Backhoe -- no trailer #30
I've driven my backhoe 30 miles and it was misserable. Something that I didn't expect was all the dust thrown up by passing vehicles. You need gloves, a face mask and saftey glasses if you are driving where other cars will be going past you!!!!!!! I pulled into a gas station and bought some cheap gloves, a bandana and sunglasses when it got so bad that I couldn't take it anymore.
As for flat towing it, I think the risks far outweigh what savings you might get by trying to do this. Can your truck handle the weight? Stoping? Will the bearings hold up to any amount of speed? There isn't a suspension on them, and what happens if you hit a rough spot or a pot hole? I'd hate to find out!!!! How are the axles lubricated? On my backhoe, they are lubricated by the hydraulic pump, which means that the engine has to be running to power the hydraulic pump. I don't have gear oil in my axles. If you pull it and the axles are not lubricated, what kind of damage will you cause? How do the front wheels turn? Mine are on hydraulic cylinders. Again, the engine has to be running to power the hydraulic pump, so the steering wheel can turn the wheels. What happens when you try to turn and the front wheels stay in the straight ahead position? My tires are big and heavy. They are not balanced. At what speed does this affect the drive, ride and towability of it? I don't know and I don't want to find out what happens when that speed is exceeded.
I've paid $500 to have my 40,000 pound dozer towed by a low boy an hour each way, or two hours total on two trips. I know rates are different all over, but I'm thinking that you should be able to find sombody who will tow it for you for half of that amount. Have you tried contacting the different dealers in the area to see who they hire to haul equipment? Some do it themselves and might do this for you, others hire it out and will tell you who they use.
If you do this and something goes wrong, do you have insurance that will cover the damage to other vehicles or buildings?
Good luck,
Eddie
/ Flat Tow Backhoe -- no trailer #31
I've got to go with the crowd and hope not to see the results on U-tube if you flat tow it. The tractor just isn't designed for that.
Your rental yard 10k trailer will not haul a 9k machine legally. You have to take the trailer weight into account. At least you would have brakes though, if you have a brake controller.
Good luck,
MarkV
thanks for providing real information on how to flat-tow a backhoe,
this is what I was considering doing, and clearly it works.
the big rear tires on this old backhoe are brand new.
/ Flat Tow Backhoe -- no trailer #33
Regardless if it could be done or not. It can't possibly be legal, that should concern you. I'm not the safety police and I do things others might be afraid to do. But I would not do something that is illegal or puts others at risk.
I still can't even picture it. A wobbly old TLB going down the road at 30 MPH :eek: Hitched to the back of a truck!
I would do it from here to my brother in laws, 2 miles away, around the corner, but not 70 miles holding up traffic.
JB
/ Flat Tow Backhoe -- no trailer #34
How many ways can this go wrong? It might be illegal. It might damage the tractor as it may not oil correctly. It might be dangerous as they aren't designed for this. I like a guy that is gutsy and will try something, but I think this may go from gutsy to dumb. It's a fine line, I've been on both sides of it before! :eek:
There are many ways to safely haul a 9000 lb tractor. Our rollback is good for 14k, as are many of the equipment haulers. Lot's of goosenecks are rated at 14k-20k, leaving 9k of capacity or more. And there are 14k bumper pulls. So you are trying to come up with a creative solution for a problem that has many safe solutions already.
We had a 35k load we needed to haul that was bigger then we go do and we did not want to pay the $175/hour for a lowboy. So we called a local contractor who hauls his own big stuff. He was slow, so he did it for $100/hour. Worked great. You might try somethying similar.
Best of luck, be safe. Or if you decide to push on, please take good video.
2012 International (A59230)
2012 International...
2014 Freightliner M2 106 T/A Terex Commander C6060 60ft Digger Derrick Truck (A60352)
2014 Freightliner...
2026 Kearney 102" x 32' Gooseneck (A60462)
2026 Kearney 102"...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
GUIGONG CLG9035E EXCAVATOR (A62129)
GUIGONG CLG9035E...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
