flat tow? (and stumbled, stalled, no start)
   / flat tow? (and stumbled, stalled, no start) #1
timo
se michigan
So was brush hogging field today and '12 DK40se stalled. Would start up and run a bit and then stall again. fuel gauge wasn't on E but added some fuel incase it wasn't reading right. same story....now won't even start.
immediate question is...
1.) can I flat tow with the hst in N to get back up to the barn? Have admonishments about towing hst lawn tractor but couldn't find anything about this one.
Next...
2.) any thoughts on issue? seems like fuel starvation to me. Only 68 hours on clock and was serviced at 50.
thanks
   / flat tow? (and stumbled, stalled, no start) #2
I don't know anything about towing a HST, and I would not do that until I had a definitive answer. Have you removed the fuel bowl and examined the contents? Pour it into a clear glass jar & look for water in the fuel. The fuel sender on at least the CK30 and DK 40 is notoriously wrong. Mine reads "E" and still has 4 gal left in it, so I doubt you ran out of fuel.
   / flat tow? (and stumbled, stalled, no start) #3
Hope it's something simple. I don't remember reading anything about towing in the manual, but in N the HST is totally disengaged so it will be fine.
   / flat tow? (and stumbled, stalled, no start) #4
not an expert, but I would put the tractor in Neutral and be sure the 4x4 is in the OFF position, then I would tow it without any fear
   / flat tow? (and stumbled, stalled, no start) #5
Tow it from the drawbar at the rear end. The front wheels should follow, or you could strap the steering in center position. Range selector in neutral, PTO disengaged and brakes, 4x4 and key off.
HST lawn tractor has hydraulic motors for steering that need to be disengaged before moving.
Your DK may have air in fuel line, check position of valve at fuel bowl, and make sure bowl is secure in housing.
Who did your 50hr svc.?
2019 BIG TEX GOOSENECK  TRI AXLE 34FT 2 CAR HAULER (A52576)
2019 BIG TEX...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A52748)
2006 Magnolia Dry...
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A52576)
2014 HINO 338 26FT...
2009 Chevrolet Traverse LS SUV (A51694)
2009 Chevrolet...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
2019 FREIGHTLINER M2 26FT BOX TRUCK (A52577)
2019 FREIGHTLINER...
