Flat rear tire
   / Flat rear tire #1
MarlinSlayer
Bronze Member
Collierville, TN
Ford Jubilee!
left rear is leaking.....I had this thing stuck in the mud the last time it worked.....Is it conceivable that there is just crud in valve stem??????:rolleyes:
   / Flat rear tire #2
Maybe. I'd check the valve stem area with soapy water or store-bought leak detection fluid.
Good luck.
   / Flat rear tire #3
give a shot of air to the tire to get it pumped up, then wet the stem to see bubbles. if none, wet around bead. as said. a lil soapy water in a squirt or spray bottle helps.
many tiems these are tubed tires anyway.. so a leak OTHER than the stem means you need to break it down to patch / repalce tube, and celan up rim, etc.
2021 JOHN DEERE 648LB GRAPPLE SKIDDER (A52705)
2021 JOHN DEERE...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2011 Mitsubishi Outlander AWD SUV (A51694)
2011 Mitsubishi...
2007 Nissan Armada SUV (A51694)
2007 Nissan Armada...
2025 K2010 UNUSED Chicken Coop (A53117)
2025 K2010 UNUSED...
2016 Chevrolet Malibu Sedan (A51694)
2016 Chevrolet...
