Tires flat rear tire
   / flat rear tire #1
stevestud99
iowa
bobcat ct230
well i had my 1st flat on tractor tire rear just lately i took it off. Took tire to garage for i could take a better look at it took tire half off rim checked inside didnt see anything protruding threw it thought i had a nail in it or something ,well didnt see anything so wanted to fill it up so put tire back on rim wow what a fight kinda , got it back on ,tried to fill ,no luck on getting bead to set.i struggled approx 5 hours on this thing using ether. using strap method ,lots of soap . nothing worked, strap looked like it was going to work pushed sides in but i put air chuck on it and still air blowing threw it like nothing , well after all this said **** with it put it in truck took to town and the guy said at shop the air valve itself was leaking air and he tightened that and used a bead blaster to fill it and he had no problems , so long story short he charged me sixteen dollars which wasnt bad considering all my time i put into it but i wish i had checked that which i didnt .anyways any comments are welcomed and maybe i should have posted on here my troubles in the 1st place , oh well lesson learned.
   / flat rear tire #2
Anyone who fixes his own problems gets beaten by a simple thing once in a while. It happens to all of us. At least I hope it's not just not you and me. :laughing:
It sounds like the tire guy did you right though.
   / flat rear tire #3
Here is another advantage of filled tires I hadn't thought of till now. If you have flat, look for the wet spot on the tire before taking it apart.
Just a tip on fixing rear tires, it is usually much easier to remove and reinstall a rear tractor tire with the wheel on the tractor.
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
Grady-White 17ft...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2014 Ford Taurus Sedan (A50324)
2014 Ford Taurus...
