Flashing Hazard Light issues
   / Flashing Hazard Light issues #1
BarnieTrk
Stanton, MI
1989 Ford 1720 (4x4) diesel-powered
Hi Fellas,
When I acquired this '89 FORD 1720, the orange, flashing hazard lights on either side of the ROPS were busted off. I bought two new (not OEM, rather off of Ebay) orange hazard lights and installed them. They were two wire units, one hot and a ground wire. I re-connected the hot wire and ran a new ground wire for each light. I turn the lights on at the dash switch, and they work as designed...... HOWEVER, they don't seem to flash very brightly and they flash faster than I think they would/should.
Questions:
a) Does this tractor have a flasher fuse - like my old truck does - or is there a flasher device built into the light fixtures?
b) If there is a fuse, do the symptoms I mentioned above sound like it could be bad and need replacing?
c) If so, where is the flasher fuse located on this tractor?
Thanks in Advance for any & all help and guidance, Guys!
BarnieTrk
   / Flashing Hazard Light issues #2
a fuse is a 1 shot deal. works till it opens, then nada.
this don't sound like a fuse.
dim lamps usually mean more load than the conductor can handle, and that includes all the old and rusty connections between battery and lamp.
fast flashers usually mean more load than the flasher module was designed originally for, if it is a thermal unit.
   / Flashing Hazard Light issues #3
Are the lights you bought strictly hazard flashing lights or are they combination turn signal / brake lights.
If they are combination turn /stop lights and have 2 wires they get ground through the mounting bolts.
Could be the cause of your dim flashing. Look at the bulbs, if the have dual filaments they are combo lights. Flashing lights only would have single filament bulbs.
Yes, there should be a fuse and a flasher. Can't help tell you where though. Since you have lights its not the fuse.
   / Flashing Hazard Light issues #4
it's not a fuse issue, if the lamp lights at all.
   / Flashing Hazard Light issues #5
The two wires are not to be used the way you have wired things. The bulb has two filaments and is intended to be a tail light and a brighter signal/hazard light.
Wiring things the way you did makes both filaments light and the bulb will be dim.
The lamp needs to be grounded to the metal part of the tractor when you bolt it unto the tractor.
You then need to experiment hooking up one wire at a time until you find the one with the bright filament.
Just tape up the end of the wire you dont want to use.
Dave M7040
Did I mention that wiring is NOT my favorite passtime? :ashamed:
No, these lights are yellow on both sides. They are not a combo tail light / hazard light; I have a separate tail light fixture that works with the headlights. The hazards only work when I turn on the hazard lights.
But with that being said, I don't know if these fixtures have two-filament bulbs or not. They do have a red and a black wire though. I was thinking the black wire was a ground wire, but I may be wrong...I suppose if these fixtures contain two filament bulbs...and I've grounded out one of the wires...it would not be a happy light.
I mounted the lights on a slab of rubber, figuring it would function as a vibration insulator, and rather than rely on the fixture being grounded via the securing nut on the bottom of the mount (which is assuming the mounting perch is adequately grounded - which, by the way, is on each side of my ROPS, which is bolted to the top of my rusty fenders) I figured the black wire was there for me to ground the fixture in case I was mounting the fixture on a non-conductive surface..... :ashamed:
I will pull at least one of the light fixtures apart tomorrow to see if they contain a single or dual filament bulb....could a dual filament bulb be used just to be brighter? IDK...... I'll report back with my findings.
Geezzzzz,,,,, Say, did I mention I'm not a wiring whizzz? :rolleyes:
Thanks again for everyone's helping hand here, Guys!
BarnieTrk :eek: :eek:
   / Flashing Hazard Light issues #7
BarnieTrk, seems like you should be able to use a volt meter, or even just a 12v test light, to determine whether your tractor's hazard light circuit already has a resident flasher. With the hot wire disconnected from the new flashers, and the switch on, do you read a steady voltage, or an intermittent pulse? If a pulse, then you have a resident flasher. If instead the voltage is steady, there is no flasher or it is defective. Whether steady or intermittent, the voltage should be a nominal 12v with a good ground on that tractor. Next, check your new hazard lights independently by grounding them and applying a steady 12v from a known source to them. If the lights flash on a steady 12v, then they have their own flashing circuitry. If both the tractor and the hazard lights have separate flashers, seems like that in itself would be a problem, but I don't know how it would present. :confused3:
   / Flashing Hazard Light issues #8
Usually the bolt and nut that hold the light to the tractor is your ground.
My guess would be you have a two filament bulb in there, one wire for each and your connected to the
dimmer side(park) of the bulb.
Or, the twelve volt supply to the bulb is weak due to corrosion.
No, these lights are yellow on both sides. They are not a combo tail light / hazard light; I have a separate tail light fixture that works with the headlights. I will pull at least one of the light fixtures apart tomorrow to see if they contain a single or dual filament bulb....could a dual filament bulb be used just to be brighter? IDK...... I'll report back with my findings.
Well, I just inspected the bulbs. Yep, sure enough, two fliaments in the single bulbs.
Are the lights you bought strictly hazard flashing lights or are they combination turn signal / brake lights. If they are combination turn /stop lights and have 2 wires they get ground through the mounting bolts. Could be the cause of your dim flashing. Look at the bulbs, if the have dual filaments they are combo lights. Flashing lights only would have single filament bulbs.
Well George, the bulbs in these flashing (only) lights have two filament bulbs. Chalk this up to my luck to have odd ball light fixtures.
So Fellas, I guess I'll tear the wiring apart and attach both fixture wires to the single hot feed wire, ay?
BarnieTrk
   / Flashing Hazard Light issues #10
Does the tractor have rear yellow lights? I have turn signals on my tractor and with the ROPS off (can't get under the irrigation pipes with it up and since I have to put it down it is easier and less obstruction to take it all off) I don't have the forward turn signals. With out the forward turn signals it flashes faster. A lot of cars will flash faster when one turn signal is out letting you know there is a light out. Of course it doesn't tell you which is out but does let you know there is a problem.
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
KOLDWAVE KWK14BEA1AA0 PORTABLE ELECTRIC AIR (A51248)
KOLDWAVE...
Ranger Welder (A52377)
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
LG TRUE BALANCE WASHER & DRYER (A51248)
LG TRUE BALANCE...
GENERAL ELECTRIC HOE WASHER & DRYER (A51248)
GENERAL ELECTRIC...
