Flange leak
   / Flange leak #1
idaho2
SW WA / North Idaho
Mahindra 5530 4WD Turbo - Gear,
Any 08' 5530 owners, have you had a leak at the hydraulic suction strainer housing flange at the transmission connection. I replaced the O ring but continues to drip although less than before. Question I pose is would a fatter O ring solve this annoying drip.
Idaho2
   / Flange leak #2
I have had this trick work for me in the past. Try wrapping some teflon tape arround the joint and oring. Be careful to keep the tape more toward the outside of the joint, because if you get pieces of the tape in the hydraulic oil it could cause pump damage. I think if you use a fatter oring, you will just damage the oring when it goes in. Good luck with it.
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
2025 6.5ft 6 Drawer Workbench (A50325)
2025 6.5ft 6...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
KOOMEY INC VALVE ACTUATOR (A52472)
KOOMEY INC VALVE...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
GENIE MAN LIFT (A52472)
GENIE MAN LIFT...
