Flail Mower flair mower blues
   / flair mower blues #1
851 roger
Bronze Member
Wheatland, Oklahoma
Ford 851 Powermaster
I have a flair mower (60") that has a pretty good viberation. All the bearings are good and the shafts appear to be straight. The drive belt and idler pully are good. There are several cutters and the part that holds them missing. Could this be it ??? Where do I start ??? HELP It was free so maybe a good boat anchor! Huh
   / flair mower blues #2
That is it, 99% likely. A flail needs all the blades and clevises in order to be in balance because the shaft spins over 2000 rpm., any blades missing cause destructive vibration.
   / flair mower blues #3
LORDY, LORDY, LORDY!!!!!!!!!!!!!!
Its not ready to become a boat anchor in any form.
You are missing knive hangers and grass slicers and that is
the only problem.
This problem with vibration is a "no problem" type of repair.
Until you can get grass slicers and new hangers you can do the following to
continue using it IF desired.
Please do the following repair exactly as I tell you to do it if you need to
continue using the flail mower.
On the flail mower rotor you will find a knive hanger which is opposite the
hanger that is missing or has broken or missing knives.
Remove the hanger and knives opposite the missing knives-hangers etc., and
this will bring the rotor back into balance for you.
Remove the hanger that has missing grass slicers. Remove the hanger and
knives opposite this one to maintain a balanced rotor.
This way you can safely use the flail mower without damaging it.
You will have rooster tails in the lawn or brush until you replace the knives
and hangers that are missing or damaged.
You can go back over thses areas to mow down the rooster tails if desired.
Be sure to purchase the replacement nylock nuts or use red loctite for the
knive hangers. Its a good idea to replace the hex bolts with Hex head cap
screws being "Allen Bolts" as it will save you many bashed fingers and your
allotment of &*()(*&^%$%^&*(*&^%$ words. :thumbsup:
   / flair mower blues
Okay, I'll try to save ther beast for now, but it will have to wait for some warmer days!
Thanx
   / flair mower blues #6
He said its a flair mower. It uses jets of settleen to burn the grass, weeds, shrubs and dandy lions. Then you pick it up in a wheel barrel.
   / flair mower blues #7
No No, that's a flare mower you're thinking of. A flair mower cuts, conditions and braids the grass to give it a full bodied bouncy sheen.
2017 Jeep Grand Cherokee SUV (A55853)
2017 Jeep Grand...
Kawasaki Mule 2510 4X4 Utility Vehicle (A55853)
Kawasaki Mule 2510...
Mini John Deere Truck (A55853)
Mini John Deere...
2012 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTN6 LIGHT TOWER (A55745)
2012 WACKER NEUSON...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2017 CHEVROLET SILVERADO 2500HD (A55745)
2017 CHEVROLET...
