Flail Mower Flail vs. Rear Mower ?
   / Flail vs. Rear Mower ? #1
BigAl
Platinum Member
California , Idaho and a little island in Panama
Kioti DK45TLB
Ok all you grass mower guys out there ! I have another question on which is better for Very tall pasture grass ! 3 & 1/2 foot high . Will my new flail mower cut it down or would a rear mower work better ? I know what your thinking !!! So go try your Flail mower and find out !!! I would like to do that ,but I ran my foot through a ladder and then fell off /forums/images/graemlins/crazy.gif, so Momma and the Doc say "No Way" you get on a tractor for about 9 more weeks until the ankle starts to mend /forums/images/graemlins/mad.gif! If I need a rear mower I can start looking around now since Momma hid the tractor keys . I would appricate your input . Oh! and how hard is it to hot wire a tractor ? /forums/images/graemlins/grin.gif
Big Al
   / Flail vs. Rear Mower ? #2
At 3 ½ foot you should be bailing it… that is too much to cut and leave laying over the grass.
Your flail will mulch it better but it is going to be very s l o w going as that is a lot of hay to process. A rear shredder will cut much faster BUT you are going to have large windrows of grass.
You should see if anyone in your neighborhood could use it for feed, they could swath and bail it… remove it and then you could follow up with your flail to finish cut it. KennyV.
   / Flail vs. Rear Mower ? #3
See these old threads:
Finish Mower vs. Brush Hog
Clearing Brush-Best Attachments
Rotary Cutter questions
Rotary vs. Sickle vs. Flail vs. MMM
Flail Mowers
Brush Blades on Finish Mower
Rotary Cutter Advice
How to Service and Use a Brush Hog
Advice on Rotary Cutter Needed
A couple of things to consider are: what is your PTO hp? Is your flail mower light duty, medium duty, or heavy duty? Light duty has knife blades which cut and is a finish mower. Heavy duty has hammer blades which break heavy vegitation and gives a rough cut. If you have enough PTO hp, the Woods RM990 is a RFM which has stump jumper type heavy pivoting spindle blades and could be a good choice. I agree with Kenny though. Have someone bail it for you and make some $ while you do nothing but watch.
2011 CATERPILLAR D7E HI-TRACK CRAWLER DOZER (A52707)
2011 CATERPILLAR...
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2015 Ford F-350 Service Truck (A55852)
2015 Ford F-350...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
