Flail Mower Flail question
   / Flail question #1
n3ra77
I have read everything I could find on Flail mowers but wanted to check a couple things out a bit more since they are new to me. Flails have been well discussed recently, so apologize up front for the redundancy. :)
I would like to use a Flail to cut a couple acres of overgrown grassy area in amongst trees (not close very close together), next to a wet detention area. After I get it cut once, I will keep it cut every month or so. The grasses will generally then only be a foot or so high and maybe the area will have a few small saplings or a small branch or 2 that I probably won't be able to see will find its way in there as well. The occassional other junk that shows up in these sorts of areas (rock here or there) will likely be there too. I am not planning on making this a finished grass area at this point.
The reason I would prefer a flail is the area needing cut is within 50' of a couple houses and there are a fair number of kids (mine included) in the area as well.
The local dealer has a H40 Befco available and it has 3 blade options (three choices of blades are available:fine cut, detach & Y blades). I want to make sure I understand which blade, if any, would be appropriate for my application. It also has Optional equipment of a Drive line with overrunning clutch. Worth it?? Perhaps a Caroni would be better than Befco? Here is the Befco H40 link.
http://www.befco.com/products/hurricane/h40.html
Thanks in advance for you time.
   / Flail question #2
The only comparison I can make between the Befco and Caroni is price. I saw a 4' Befco at a local dealer for the same price I bought my 6' Caroni, $1,800.00
It does not seem like you need the fine cut, I doubt you will need to detach so that leaves the "Y" blades.
I hope this helps.
2012 MACK CXU613 DAYCAB (A55745)
2012 MACK CXU613...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2022 BMW X7 xDrive40i AWD SUV (A53424)
2022 BMW X7...
