Flail Mower Flail mowers?
   / Flail mowers? #1
Nuru
Elite Member
I am looking to buy a flail mower for the 1 acre of lawn, i will have to mow starting in April or May. I have been advised that if i want to cut this in less than 40 minutes and not have to pick it up every time, I should use a 72" to 84" flail mower. I would lie to know if:
This is the way I should go instead of my 54" JD MMM?
Who makes a good one that is not astronomically hich in cost? /forums/images/graemlins/shocked.gif
   / Flail mowers? #2
Seems to me that a 54#mmm would be perfectlyadequate for an acre of lawn. Why are you looking at a flail mower?
   / Flail mowers? #3
I have an 88" land pride flail, it is astronomical in price if i recall around 4500, I can do 10 acres in field in 2.5 hours, 1 acre probably 15 minutes, my advice go with a smaller flail or stick with a finish mower. I love mine but 80" + is a bit big for that small of a job.
   / Flail mowers? #4
I have a flail mower for my ATV and thought I might get one for my tractor. The more I looked into it the more I saw why they aren't that popular. They do take up less space and turn shorter and they don't throw things out the back, but they take a lot of PTO power and much more maintenance plus they are expensive. Unless there's a compelling reason to get one, I agree with the others who vote for a rotary mower of some type.
   / Flail mowers? #5
I recently was given a JD flail mower. Knives on it were well worn, and the belt stretched way out of shape the first time I used it.
It is too big for my front yard, fenced back yard, and is not a bushhog, so that leaves the rest of my unfenced yard out also.(almost 7' cutting width)
However, I went up to the church and mowed the five acre field in what seems like record time, even with the knives in the shape they were in. The field used to be a hayfield, so it is flat, with some very nice grass. Just the kind a flail mower loves.
I am sold on it!!!
David from jax
On edit:
Forgot to mention, the tractor I pull it with is a JD2555, and has about 65 HP at the PTO, so that probably helps.
David from jax
   / Flail mowers?
My memory indicates the the 54" JD MM cuts at a rate of 1 acre per hour on flat ground, and the 60" custs at a rate of 1.1 acre per hour, and the JD solutions for clippings pick-up are too expensive. I have a mulching set-up on my 54" but i need to get it repaired as i hit a few stones at my old property. I was looking at getting a larger mower deck and got to looking at flail mowers as an option. i want tto get it done as quick as possible and if I don't have to pick-up the clippings, even better. /forums/images/graemlins/smile.gif
That cost is a hurdle though /forums/images/graemlins/mad.gif
   / Flail mowers?
Thansk for the advice, I am now looking at a 72" as an alternative, but I would like to spend no more than 3500 for it. i plan to keep my MMM also, as it does a good job with its mulching configuration. My concern is that it needs to be cleaned quite frequently to maintain the good cut, and to do that correctly you need to raise the tractor or take the unit off to do it. with the 3PT flail, i can just lift it or use a floor jack and get it up into the air for power washing. I am also looking at used flail mowers too. /forums/images/graemlins/smile.gif
   / Flail mowers?
More maintenance? Can you be more explicit? /forums/images/graemlins/confused.gif
   / Flail mowers?
Wow, that seems to be the same thing i have heard from the dealers and other users who have them. If I get one and it is used, I would refurb it as required. One concern I have with it, is how does it handle sloped areas? Is it just the angle you pick?
   / Flail mowers? #10
I use a big Befco C50 finish mower w. a mulching attachment ...works fine, nothing to pick up ...but, you are limited to 2mph or less so that it can do its "cut-everything-twice" thing. Comes in 4' to 7' wide swath cut.
Miller Spectrum 500 DC Plasma Cutting System (A54811)
Miller Spectrum...
S/N: 5D121002416 (A55787)
S/N: 5D121002416...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A53473)
2022 Quick Attach...
2007 International 4300 Dump Truck (A51692)
2007 International...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
Ammco Brake Machine (A55758)
Ammco Brake...
