Are you recommending the Flail in all cases?
G'day,
Yes, I would.
I would advise you to purchase the flail mower with no
hesitation or second thoughts.
I have owned them for thirty plus years and would buy a
second one if I needed one.
I have the same mower my father bought and it has
been in use since the very early1980's with no problems
and normal maintenance. We replaced the original flail
mower rotor bearings for this flail mower the first time
6 years ago after 25 years of use.
The flail mower is the better and safer mower to use in all cases-
road side verges, drainage ditches and normal lawn mowing can
be accomplished with the same mower eliminating the need to
purchase a mower for simply mowing the lawn.
The flail mower will not throw anything it contacts like a slasher
/rotary cutter would as the verticut method with the side slicers
or scoop knives fold back if it hits an object.
It will work very well and reduce the clippings to the smallest
size for you.
The other benefit which comes at no extra charge is the rear roller,
it stripes the lawn for you with no extra charge and the flailmower
is much shorter than a slasher and if you purchase one with a hydraulic
side shift you will have a machine that can mow close to walls and fences
with no difficulty.
_____________________________________________________________________________________________________________
Once you go flail you never go back:thumbsup::licking::drool:
Pronovost or not at all!!!:thumbsup::licking::drool:
