I'm new into the flail mower thing.
I'm wondering what you folks use to support the
mower when you need to get under it.
Mine weighs just over a ton and there's no way
I'm crawling under it with just the three point
holding it up.
Heavy duty jack stands or something similar?
Thanks for the help.
Hello flying m,
Welcome to the Flail Mower Nation.
Let me guess; you have baling wire wrapped around the flail mower rotor? or an old garden hose that tried to escape? or lots of nylon twine to remove?
If there is anything wound around the rotor at either end it has to be removed as it will heat up the bearing housing and the bearing.
Which brand of flail mower do you own?
If your mower is new with low hours, what makes you thnk you need to work on it?
Have you found broken knives or knive hangers?
Now as far as working under the flail mower the only time
you are ever under it is when you are replacing side slicers
or knive hangers only.
Dont even think about jack stands for this job!!!!!!!!!!!!!!!!!!!!
If all you want to do is wash and scrape the crud off of it dont
worry about it too much. If you want to wasg the shroud all you
need to do is use a hose nozzle and hot water if you can spare the
hot water for it.
The fine grass dust will not wash off easily inless you go to a carwash
with it or you own pressure washer.
I would be more worried about losing paint if you use a pressure washer.
My flail mower is 33+ years old and has 95 percent of the original paint.
If you think you need to spend a lot of time working on the knives
its better to drain the gear box and roll it over on its back as you will have
an easier time doing repairs if you have to replace knives and hangers.
Its safer than crawling under it as you can use the top link to pull it back over.
if you have front end loader for your mule, use that to put it on its back and then work on it.
If you have a pairs of broken knives to replace its better to go to a sawmill
and buy some hardwood blocking to support the flailmower side weldments
making a cribbing stack of hardwood blocks to support it
To do this properly you need level ground to build the wooden cribs to support
the mower on both sides. and under the rear roller as well to prevent it from
tipping back or falling foward.
If you have not done this already you can make a mower dolly to allow you to store the
mower out of the weather. just build the mower dolly tall enough out of hardwood blocking or soft wood 6 by 6's to permit you to crawl under it to work.
Many of the members have snowcaster dollies and flailmower dollies
and they have uploaded images of them for the members to see.
If you do not have a hardwood saw mill nearby the better solution is to
simply put the mower on its back if you have a lot of knives to change.
Welcome to the forum and The Flail Mower Nation
